RS Barn VS OEM Flywheel
#41
disks are on their way to pete as we speak
I have just instructed my Web guy to add new pricing for Motorsport Flywheel @ $679 and introductory price for Spring centered Clutch Disc @ $299
In anticipation of the clutch discs coming, I ordered a larger quanity of Flywheels and got a better price at the manufacturer.
This was the game plan early on to offer a performance upgrade for equal to or less than OE pieces
Pete
ARRG, I hear a sucking noise coming from my wallet.
Pete,
You are able to get the factory pressure plate as well, not the newer heavier pressure unit, right? Now, here's a new question. I finally got the 968 flywheel lock. Does it work with the new flywheel or would I now need a 944 style flywheel lock? I'm assuming that the new solid flywheel is thinner than the DMF or is it but it has a built in offset?
--Tony
968 flywheel lock
Standard 968 Flywheel lock works PEERFECT!!!!
Great work guys, I think you really worked hard on this. Thats a great price point on the flywheel.
Same with the clutch disk. Its not like you are going to sell 25,000 of these. I am surprised you are able to keep the prices within grasp. <img src="/forum/images/smilies/968/biggrin.gif" class="smilie" alt="" />
Only if this stuff would have been available last year when I replaced mine.
I replaced mine last year and still may go down this road. I have not made a cash infusion to the Newtown, Pa economy in a year or so.
[quote name='Mark' post='47346' date='Feb 11 2008, 09:54 PM']I replaced mine last year and still may go down this road. I have not made a cash infusion to the Newtown, Pa economy in a year or so.[/quote]
If I keep mine, I may do this as well.
Any word if the new clutch fits a Fidanza yet?
The Spring centered clutch disc will fit with a Fidenza. A few mods needed but I can guide.
Pete
Thanks!
If I keep the car I will be doing this.
Light flywheel seems interesting mod. would you have any performance specs how the flyweel affects to the car performance / characteristics? (G-tech, dyno, etc.)
Any effect on torque / hp - some claim there would be loss of torque in the lower rpm's, how does it feel?
how is the spring centered clutch working with the LWF, compared to stock OEM clutch + FW?
there is an interesting site with an explantion of the "torque loss" - it isn't really torque loss, but rather a sensation of it, due to the lack of the resistance of the heavy flywheel
what you "feel" is not always what is really going on
a good analogy would be the difference one might feel if they had big brakes up front, versus smaller ones - the nose dive from the big ones might lead you to believe it's braking better, when in reality, it could actually be upsetting the balance, and placing it all on the front - it might not actually stop faster - (before any of you "big red" fans jump up and down, there are a lot of tother things involved and required to make bigger brakes work well, and yes, they can be better if those are done)
another good one, and is very common, is the sensation that happens when you stiffen a rear suspension - the car "feels" slower - this is because the weight shift to the rear under acceleration is no longer so dramatic
here are some links to read:
http://www.uucmotorwerks.com/flywheel/index.htm
Those articles are excellent translations of engineer-speak into layman language. Thanks for digging them up, Flash. Now all I need is a spring center clutch and appropriate pressure plate for 409.8 ft-lb <img src="/forum/images/smilies/968/cool.gif" class="smilie" alt="" />
no worries - that's what this site is all about
i would think that the 3200# plate i have should do the trick
So, Pete and Flash, what's the result of your work on the new clutch and flywheel? Does the combo reduce the chatter and rattle of changing to the SMF alone?
I'm not going to change until the next time I need to replace the clutch but that's a prety good time to consider it. I definitely can live with the changed driving characteristics but I don't want to drive around with a lot of noise.
yes - the description of how much and when is talked about above
Pete.
Im interested in one of your flywheels,, BUT,,
Can you tell me , the "motorsport" flywheel you supply,, Is it one that you have manufactured OR is it a "remodeled" Fidanza .???
Is it an alloy fly or steel.??
As the pic that is now on your site doesnt look the same as a "Porsche Motorsport" type.???
Just wondering if you read this Pete.???
And will i be getting a reply.???
the RS Barn website is being updated as we speak and will have all of the specifics any time now
05-05-2011, 02:17 AM
04-06-2011, 12:02 PM
Last Post by firefish
08-28-2009, 02:01 PM
08-19-2009, 01:22 PM
04-08-2008, 09:53 AM
Last Post by Anchorman
09-05-2007, 11:05 PM
