Threads: 19
From your drawing, looks like the alternator wiring comes off the alternator in the direction of the engine block. I didn't take any pictures of my engine before I removed the alternator. Right now I have the wiring coming off the alternator going away from the engine block, then it is wire tied to the engine mount bracket, then to a strap at the bottom of the oil seperator, then to a strap that mounts onto the bellhousing.
What was the routing of the factory wiring after it leaves the alternator?
'92 Midnight Blue 968 Coupe
Threads: 19
Tama, I know there is some wiring that goes in the open area just underneath the intake. So, in simple words, this other wiring travels along the top of the block close to the area where the head bolts to it. Does the stock alternator wiring follow that route also.
In simple words, my current routing follows along the block just above where the oil pan bolts to it.
(This post was last modified: 07-17-2012, 06:43 PM by
MB968.)
Threads: 19
Lear, my routing is esentially the same as yours except, with the much stiffer (due to larger strand diameter) #4 wire, I couldn't easily bend the wire back to the oilpan without putting undue strain on the wire/connector. So, I just routed it behind the engine mount bracket as shown. After I took these pics a couple of days ago I added a ziptie to attach the wire bundle the engine mount bracket.
(This post was last modified: 07-18-2012, 01:46 PM by
MB968.)
Threads: 19
[quote name='Lear35A' timestamp='1342638887' post='129567']
I found a piece of AWG #5 cable with finer strand wire. It's from an old welder cable. Should do the job and is very flexible.
Yeah, in the table I posted, looks like AWG #5 has a crossectionaly area of 16.8 mm squared vs the stock which shows on the electrical diagrams as 16 mm squared. So, the #5 should work great (you probably already knew this, but thought I'd put in the actual numbers from the table and the wiring diagram in case anyone unfamiliar wants to make a similar comparison for future wiring). You might have to go to an electrical supplier to get the connectors, as #5's arean't that common in the retail world.
I was lucky and had a die set for spark plug wires that worked. Had I not, I would have used a small diameter pin laid longways on the connector to crimp on the connector (using a vise). You could probably use the end of a finish nail punch if you don't have any small diam. pins. You don't want to use a chisel point punch, as it could do enough damage to the connector that it might loosen with time.
