Threads: 27
I was able to reach the back of the alternator, with small wrenches, from the top, with no problems. Certainly some contortions required.
Threads: 19
Thanks to astroede's post a month or so ago, I was able to replace my wiring with a new harness while the engine was out of the car. I made the harness from parts obtained from the local Home Depot. Below is some info on crimping the large #4 wire lugs, and wire sizes that might be useful to others doing the job themselves.
___________________
When I found that the alternator-to-starter wire that I had was bare, and just wrapped in tape, I decided to replace it. I now have a new #4awg replacement wire. I found some old dies that I had to crimp ends on custom spark plug wires which worked well at crimping the new lugs on the #4 wire. I also put another layer of shrink wrap over the top of the other two wires; didn't want to deal with the factory two pin connector and new wires. So, now have a much improved harness that should stand the test of time.
Astroede, I finally found some good cross references between metric wiring measured in mm squared and AWG. I came up with the same #4 awg for the alternator-to-starter wire, and #16 for the alternator voltage regulator. But, the wiring diagram for the '92 968 shows the starter solenoid wire as 4 mm squared. A #12 awg only shows as 3.3 mm squared, and since we can't easlily buy #11, the correct replacement size for the starter solenoid looks to me like it should be a # 10 awg.
The reason that the cross-section of the wire may be misleading is that wire sizing and thus conversions actually look at the total crossectional area of all the copper strands added up. So, you can't accurately use the OD of the wire to compare two wires if the # of strands/strand diameter is different. Very thin stranded wire will likely have a smaller OD for the same AWG number as a larger stranded wire. Anyway, the table below provides a good ref. (I compared a couple of reliable sources to insure it's accuracy.)
AWG Number Ø [Inch] Ø [mm] Ø [mm²]
1 0.289 7.35 42.4
2 0.258 6.54 33.6
3 0.229 5.83 26.7
4 0.204 5.19 21.1
5 0.182 4.62 16.8
6 0.162 4.11 13.3
7 0.144 3.66 10.5
8 0.128 3.26 8.36
9 0.114 2.91 6.63
10 0.102 2.59 5.26
11 0.0907 2.30 4.17
12 0.0808 2.05 3.31
13 0.0720 1.83 2.62
14 0.0641 1.63 2.08
15 0.0571 1.45 1.65
16 0.0508 1.29 1.31
17 0.0453 1.15 1.04
18 0.0403 1.02 0.823
19 0.0359 0.912 0.653
20 0.0320 0.812 0.518
21 0.0285 0.723 0.410
22 0.0253 0.644 0.326
23 0.0226 0.573 0.258
24 0.0201 0.511 0.205
'92 Midnight Blue 968 Coupe
Threads: 77
The install really wasn't the bad for me. I didn't remove the alternator, just unbolted the cables from the alternator from the top of the car. Shouldn't take more then a couple hours for all the cables.
Threads: 77
You can find all the electrical connectors and pins and what not in PET.
Threads: 19
[quote name='Lear35A' timestamp='1342449311' post='129435']
I made this drawing and sent it to Robby. Look OK?
Found the old/original alternator to starter cable. From center of eyelet to center of eyelet, it measured 129mm, or ~50 3/4 inches. As far as I can tell it is the original cable, as it has no insulation, only the electrical tape wrap that someone else had done as a repair. Looks like the cable length without the ends is 125mm or about 49 1/4".
I measured the small wires from the 2 pin connector. I get about 21" from the connector to the other side of the wire strap on the bellhousing where these two split off from the rest of the cable.
I think there is also a dimension issue with the drawing. If you take 20 inches away from both of the small wires, they don't add to the length of the alt/starter wire.
(This post was last modified: 07-16-2012, 06:44 PM by
MB968.)
