Relay/Fuse box breakdown with pics
I was told that this box was shorting out and it was causing all the problems. I don't see anything wrong with this, so I probably just had harness plugs that were not seated properly. [img]style_emoticons/<#EMO_DIR#>/dry.gif[/img]
check it out
Mike D.
'94 Metalic Slate Grey Coupe w/ M030
'74 914-6 3.0 Hot Rod
I've done it before. But I there is a shorten circuit. You can see that by the "melt" or burned tracks. I looked at the pictures but I think your fusebox is in good condition.
Yeah, after what I was told by the mechanic I fully expected a melt down, burned copper, maybe some corrosion. But nothing, clean as whistle inside (now it has finger prints). I'm going to use a little denatured alcohol, rub it down and carefully put it back together. I'll just stash it for a spare....
Mike D.
ha! yeah I took mine apart once - trying to track down a short - did it as much out of curiosity as I did really expecting to find a fault in there. the job is not for the faint of heart - keep the wiring diagram close by!
Last Post by hot968
08-03-2022, 08:25 PM
Last Post by Daniel S
07-07-2018, 08:33 PM
Last Post by tamathumper
03-29-2012, 09:16 AM
03-05-2012, 09:12 PM
Last Post by josephsc
04-08-2009, 02:28 PM
Last Post by unknown4u
03-11-2008, 02:55 PM
