Headlight Relay?
right headlite lites but inoperable up and down // left side ok / / checked fuses #2 has 12v // #16 has 12v when headlight is to be closed// #32 12v when headligth should be open // took cover off relay G17 18 and watched contacts // front half of relay - bottom contacts open and close cycling lites on and off // top half contacts do nothing // back half of relay - top contacts open and close when cycling lites but bottom half does nothing // with G17 18 removed , checked pins 1 and 2 for front half of relay, have no power but pin 2 in back half of relay has 12v constant and pin 1 has 12v when cycling the switch help! Thanks!
is anybody else having as much trouble reading that as i am? am i just getting old?
<img src="/forum/images/smilies/968/blink.gif" class="smilie" alt="" />
Please try again
thanks - that's much better
ok -
first, check the power and ground of that motor - the connector is right next to it
second, see if you can operate it manually (there is a knob) - lube the mechanism with tri-flow while you are in there
then, since i assume you have checked all fuses, moving on to the relay, i would substitute a known working one in there - can you find a buddy locally to try his?
Was doing some regular maintenance for the car today, when suddenly started hearing random clicking from behind the dash. First I thought it was some animal inside dash, but then located the noise coming from fuse box.
It is this g17 g18 relay which keeps clicking randomly once in a while. Mine headlamps are ok, so is there any symptom for this clicking? Relay dying soon?
I searched this part from pelicanparts, but couldn't find the relay. would you have the relay nbr, and where to find it? I thought of replacing it anyways, since don't want to have any extra hassle in car's fusebox...
.matti
____________
Porsche 968, 1992, 6-speed, Corallic-Red.
Mods.
Engine + Drivetrain: RS Barn Flywheel; RSBarn Chip1
Chassis: Rear Seat Delete; Fiberglass hood; Lexan rear hatch; Odyssey 680 racing battery + kill switch
Suspension & Brakes: 996 Turbo Mk1 front calibers + 330x34mm cross drilled discs front; 968 CS Cross drilled discs rear; Ferodo DS2500 brake pads; Speedline Corse Magnesium Wheels (18''); Shark Motorsport strut brace.
Coming up:
Adjustable Camber plates. m030 Sways + coilovers probably next summer... *sigh*
maybe slotted 2-piece front brake discs, If I find a good deal. Smile
my light stays up as well. the local dealer says I need a new motor for the light $1200 part from germany. any other options out there??
Used
I'm starting to part out my old 968 cab with 80k miles -- and just removed the headlights. Drop me a line if you need a used part.
Last Post by hot968
08-03-2022, 08:25 PM
Last Post by Daniel S
07-07-2018, 08:33 PM
