relay for cruise control?
is there a fuse or relay for cruise control? if so where is it? Thanx, Matt <img src="/forum/images/smilies/968/huh.gif" class="smilie" alt="" />
92 Porsche 968 Coupe Red (first Porsche)
66 Shelby GT350 (real)
2007 Altima (wifes)
2001 F150 SC
66 mustang fastback
65 Shelby GT350R (CLONE)
65 Mustang 6cyl Convertible
99 Taurus, new driver to take
pressure off 968
The control unit is hidden under the fusebord. Mounted at the driverside. If you look under the steeringcolumn you will see it directly.
On the cover from the fusebox you can read witch fuse it is.
[quote name='unknown4u' post='48860' date='Mar 8 2008, 05:12 PM']The control unit is hidden under the fusebord. Mounted at the driverside. If you look under the steeringcolumn you will see it directly.
On the cover from the fusebox you can read witch fuse it is.[/quote]
there is nothing on the bottom of my fuse box cover pertaining to cruise control. are u saying there is another box under the main one? thanx,Matt
2007 Altima (wifes)
2001 F150 SC
66 mustang fastback
pressure off 968
The extra relais and fuses are located in the left side in the footwell. See also the usermanual of the car.
Last Post by hot968
08-03-2022, 08:25 PM
Last Post by Daniel S
07-07-2018, 08:33 PM
Last Post by mbardeen
04-19-2012, 02:38 PM
Last Post by tamathumper
03-29-2012, 09:16 AM
Last Post by DaveN
03-26-2012, 07:13 PM
03-05-2012, 09:12 PM
