Threads: 59
Electronic counter measures devices are no substitute for situational awareness. Never forget to check your six from time to time.
Chris Vais
2008 Audi A5 Brilliant Black
Threads: 59
It means to look behind you or over your shoulder. A lot of pilots get shot down because they neglect to look aft ward to see what is following them. Pilots use a clock face to describe where something is in the sky. Twelve-o-clock being on the nose and 6-o-clock being to the rear. The terms high and low are used further describe the position as being higher or lower in elevation. Thus twelve-o-clock high means on your nose higher in elevation, nine-o-clock low means off your left wing and at a lower altitude.
Chris Vais
Threads: 59
F-4s had poor rearward vision. I used to clear my 6 by periodically executing an aileron role or a barrel roll just to make sure nothing was coming from behind or below.
Chris Vais
Threads: 167
"Goose, you just put on the brakes and they'll fly right past you..."
"You're gonna what???"
[quote name='Chris Vais' timestamp='1390501512' post='154553']
Threads: 1
[quote name='williamoss' timestamp='1390506707' post='154558']
ok if you think they work which is a good one to buy, model number and brand that gives both front and rear protection and good for both radar and laser?
It depends, do you want one for Migs or cops? <img src="/forum/images/smilies/968/rock.gif" class="smilie" alt="" />
Seriously, I have used the Valentine 1 since it first came out and the Escort products before Mike Valentine sold the company. Go online and do a search for Valentine 1.
~tom
997 C2S
GMC Sonoma SLS, dd
Miata LS, Cheap Thrills
Acura TL, Wifes dd, zzzzzzz
1993 Red 968 M030, after 18 yrs, gone but not forgotten
(This post was last modified: 01-23-2014, 05:57 PM by
Tom030.)
Threads: 1
DS, Can you hum "I can't drive 55"? <img src="/forum/images/smilies/968/glare.gif" class="smilie" alt="" />
997 C2S
GMC Sonoma SLS, dd
Threads: 1
Flash,
Agree with the V1's propensity for apparent false signals however the L mode does reduce it somewhat. On the other hand it has saved my arse more times than I can count. Brand loyalty I suppose.
~tom
997 C2S
GMC Sonoma SLS, dd
Threads: 15
I've been using the Escort 9500ix for 5 years and love it. I just ordered the Redline. I'll do a side by side comparison, the Redline is rated one of the best in range.
Current: 1994 968 Coupe, 1987 944S, 2004 VW GTI 1.8T, H-D XR1200
Previous Porsches: 2000 986S, 1974 914 2.0 Blue, 1974 914 2.0 Yellow, 1970 914 1.7, 1985 928S
Previous non-Porsche favorites: 1974 Early Bronco, 1975 Cosworth Vega, 1977 Trans Am 6.6L, 1973 Karmann Ghia, 1983 Supra (turbocharged)
Threads: 46
Any of the modern BEL's are good IMO...
1994 968 Coupe - Grand Prix White/Marine Blue - 6 sp - D1R Supercharged
