power window troubles
I can only roll down the passenger window from the driver side. Also sometimes the driver window does not roll down when the switch is pushed. Sometimes if I push it several times then it will work? Does anyone think that replacing the switches will cure the problem? Thanks
Yes, or you could clean your existing switches.
I have some spare switches if you need them.
Contact cleaner or tuner cleaner from Radio Shack may help clean the switch
87 944S
19 Audi A6 3.0T
03 Toyota Tundra
[quote name='Ryan' post='56128' date='Jul 10 2008, 10:02 AM']Contact cleaner or tuner cleaner from Radio Shack may help clean the switch[/quote]
Thanks for the tips. I really appreciate all the help from this forum.
I think I can confirm the contact cleaner. I brought the switches on my seat back to life this way. Removed the switches, sprayed Radio Shack contact cleaner inside, worked them back and forth several times, and they have been fine since. The contact cleaner removes the goo from the contacts and just working the switch brought them back to life. This may work for the window switches as well.
Roland
Roland
And my mech bought a new seat switch for about $180 - arghhhhh
<img src="/forum/images/smilies/968/mad.gif" class="smilie" alt="" />
01-31-2017, 12:25 AM
Last Post by Langley968
09-15-2010, 02:43 PM
07-14-2009, 04:06 PM
Last Post by Kim
11-02-2008, 09:29 PM
Last Post by EEZATOY
08-06-2008, 03:34 PM
Last Post by Anchorman
08-01-2008, 01:51 PM
