P9021 spec for alternator/AC belt tension?
I know, this is being ridiculously anal, but a fellow forum member has graciously loaned me his P9201 tool to use to tension my balance shaft belt, but I figured that as long as I have it, I might as well use it for the alternator/AC belt as well, but I haven't been able to find the spec in the workshop manual. Anybody know what it is? Thanks.
depends on belt thickness
4.4/4.8 (mm) 8.5
4.9/5.2 (mm) 9.5
5.3/5.6 (mm) 9.5 ad 1 turn
volvo V70D5 Black
Porsche 968 amethyst
Thanks - where did you find that? Was it in the manual?
It is in mine 03-18a if i remember correct .
I always adjust this one with the car running ac fan's light's etc on (have a lift s makes it easy ) youcan actually hear if te belt is to loose .
But with the tool you should have no problem getting it done .
Get a good feel from the belts when you are done , so you can adjust/replace them next time you change them and don't have the tool .
when do you think you'll have the car on the road again ?
volvo V70D5 Black
Check with me for way to tell if you adjusted properly-gauge or not
[quote name='RS Barn' timestamp='1335058442' post='125838']
OK, I'll give you a call on Monday. FYI, my belt is right at 4.4 mm thick, so I set it to 8.5 on the gauge.
As far as when I'll have it running again, it's very hard for me to predict. I'm making slow but steady progress, so I hope in a few weeks.
Last Post by tejon007
03-27-2024, 02:25 PM
Last Post by Ryan
06-26-2019, 03:00 PM
