Hi,
I'm having problems with oil pressure gauge, it keeps the pressure readings in 5bar no matter what the situation. I've gotten info that it might be something wrong in the wires that go to oil pressure sender unit, or in the unit itself.
tried to lookup in the factory manuals to find the location of oli pressure sender unit, but didn't get clear picture.
- how to find the oil pressure sender in 968?
- how to check the wires, if they're ok? (need any substances to clean the connectons?)
- is oil pressure unit easy to change, what tools are needed? what is the best way to do the change work?
thanks for your comments!
P.S. Ordered Pete's LWFT-set just yesterday, cannot wait to get it installed, and listen the more aggressive revving of that sweet 3.0 16V.. <img src="/forum/images/smilies/968/biggrin.gif" class="smilie" alt="" />
edit. OK, after re-searching the 968 workshop manual found the pic that shows the oil pressure sender is behind the oil filter.. so, question one seems to be cleared.
