thermostat oil cooler bad
my thermostat failed , in the picture the right one is bad , stuck half open , when i heated it up i did move further but did not check a what temp .
Indications where , lower than normal oilpressure when cold .
pressure normal warm at around 2500rpm was 4.5 bar , and with bad thermostat just above 4 bar .
Pressure taking longer time to settle , also coolant temperature was acting different , hard to explain , but after owning the car for so many years you get a feel for it , and things where of .
to make sure it was bad , i drove the car for about 3 miles slow pace , outside temp around 60 degrees , not enough time for the car to heat up completly , then when i went to feel the hose and oilcooler they where allready warm , this should not happen with a opening temp of 95 c .
so removed the thermostat , which is a pain to get to , made my own tool and got it done .
Expect oil everywhere , decided to do an oil change as well , fresh oil and normal pressure indications again .
Never heard of one fail , anyone else had one go bad ??
volvo V70D5 Black
Porsche 968 amethyst
Last Post by cosimo
04-27-2015, 12:08 PM
Last Post by kwikt
06-21-2010, 02:17 PM
06-17-2010, 10:48 PM
Last Post by Kim
07-05-2009, 03:39 PM
Last Post by Cloud9...68
05-18-2008, 11:18 PM
Last Post by kwikt
08-13-2007, 10:11 PM
Last Post by 968workaholic
04-22-2007, 07:13 PM
