Threads: 10
Since my car has 62000 miles on it I decide to change out the original spark plugs, cap, rotor, and wires.
When I pulled the boot off of the spark plug in cylinder two I noticed some oil at the base of the plug. When I removed that plug it was not even hand tight. <img src="/forum/images/smilies/968/dry.gif" class="smilie" alt="" />
The other plugs look okay and none of them seemed abnormally fouled. I'm trying not to read a ring job into this but I was wondering what you all think I should do next.
Oddly enough, the cap and rotor seemed to be the most worn. The lead on the rotor was almost completely gone compared to the new one.
I thought the car has been running pretty strong. I can't wait to see what it'll be like with all four cylinders working. <img src="/forum/images/smilies/968/blink.gif" class="smilie" alt="" />
Any advice would be greatly appreciated.
________________________
[color="#3366FF"]1995 Porsche 968 Cabriolet
1997 Mercedes Benz E320
2007 Mercedes Benz ML350[/color]
Threads: 10
Thanks Bob, I'm sure you heard my sigh of relieve.. <img src="/forum/images/smilies/968/cool.gif" class="smilie" alt="" />
According to service records the car had a Variocam service at 48K miles. So I was going try and wait until ~70K miles before I did another inspection. But as you suggested, I'll keep my eye on it for now.
I also measured the resistance of the old plug wires vs the new ones. All of the new wires read ~ 4K ohms. One of the old wires read 3.1K and the other three were 4.4K.
Wierd, but I suppose that's within spec.
Thanks again!
Threads: 15
You might need new seals around the plug holes. I also had some oil pooling in the spark plug wells so I changed them out when I had the valve cover gasket replaced.
-Austin
'94 Black/Tan Coupe
