Oil Consumption
I had a rebuilt head installed on my 160,000 mile engine. Since then, oil consumption has increased markedly. Before the work was done, my oil usage was in the range of 1q every 4-5k miles or so. Since the head was changed, I'm using closer to 1q every 1-2k miles. There is no oil leakage, engine performance is no different than it was with the old head (no smoking, fuel mileage is the same, etc.) - the only noticeable change is that oil consumption is up.
Any ideas?
1 qt every 1-2k is not outside of the Porsche described parameters for oil consumption. The key word being "consumption." I used a little less than a quart in a 1k trip to PA and back. Extended highway/high speed driving increases consumption in this engine. The same was true in my old S2.
So, I'm not convinced that you have a problem. But I understand why you would be concerned. I would closely monitor both the floor and the coolant reservoir just to be on the safe side.
Ralph
'77 911S (RIP)
When I got my car it was down 1/2 quart. I was told when I had the belts done it looked beauful so no worries. Imagine my surprise when it got down a full quart to min. and all the lights came on. Not sure of its real consunption rate yet. No drops or smoke at 87000 miles. I have been made aware of the dumping into the coolant thing though. So I'm keeping a close watch seeing I have only put 800 miles on her since I got her.
Ross
Ross Carley
Newtown, CT 06470
1992 968 Tip. Cab. (Slate Gray) purchased 4/2008
1965 356 SC Coupe (Iight Ivory) purchased 10/1976 $2500 ( now undergoing complete restro help me chose a color)
1970 914-6 (Irish Green) purchased new March 1970 $6800 sold it 10 months later a real POS
1964 356 SC Coupe (Irish Green) purchased 1969 $2700 blew it up on the Tapanzee Bridge 3AM at 90+
1966 Austin Healy 3000 (BRG) purchased 1968 They came as a set $1200 for both
1966 Austin Healy 3000 (Guard Red) purchased 1968 " " " " " " "
1961 Austin Healy 3000 ( Silver Blue) purchased 1967 $400
1953 Le Francis (Le Mans White) 3 speed twin overhead cams purchsed 1966 $600
Check for oil residue in the coolant reservoir, also can check for the sweet coolant smell in the oil. It usually shows up more in the coolant reservoir. Being a 92 I'm sure some seals are drying up in there especially if it sat for extended times.
Last Post by unknown4u
12-17-2023, 08:16 AM
Last Post by J.Elenbaas
06-13-2020, 05:17 PM
02-20-2020, 08:48 AM
Last Post by MCL968
02-18-2020, 02:45 AM
07-29-2019, 02:08 PM
03-20-2015, 07:14 PM
03-07-2015, 06:45 PM
