M030 SWAYBARS - PRICE AND INSTALL
I just got a price from a local Porsche dealer for new M030 swaybars and bushings
as an upgrade for my 968, 6 pieces total: $385.06.
Is this a good price?
Is this a good DIY?
Do you need to align the car after the job?
Thanks to any 968'rs for responding!
Scott
good price if for both bars
fairly easy DIY, if you are all handy with a wrench - the car will need to be at least up on stands
no need for alignment afterward
You can get away with doing this with the car on ramps (do one end at a time, obviously). The suspension can be loaded for swaybar installs. Toughest part is sliding the bloody rubber bushings onto the bar. A little soap sure helps.
I do recommend the swaybar bracket triangulator bits from KLA (I think) for the front. Without it, my front had a tendency to "walk" and pop the circlip off the end.
both kla and tarret engineering make the bracket - great improvement
the walking you are talking about is a common problem, especially with delrin bushigns, which leads to uneven loading left to right - shaft collars solve that one permanently
Also worth looking at the solid rear swaybar mount from Racers Edge as well.
[quote name='333pg333' date='Aug 26 2006, 06:32 AM']Also worth looking at the solid rear swaybar mount from Racers Edge as well.
[right][post="25602"]<{POST_SNAPBACK}>[/post][/right][/quote]
What is the benifit with this?
rubber flexes - any flex means a delay before the swaybar starts working
Last Post by parptarf
10-28-2014, 07:35 AM
Last Post by Cloud9...68
02-21-2013, 05:56 PM
Last Post by DaveN
02-07-2012, 02:41 PM
Last Post by JWahlsten
11-14-2011, 06:19 PM
Last Post by gbarrier
04-25-2011, 09:02 PM
02-12-2009, 12:53 PM
