Removing torsion bars and Konis, replacing with coilovers
Put my two 25.5mm torsion bars and two Konis (not M030) on the scale today, then two KW coilovers to find the weight savings: just under 9 lbs. total.
i went through this when i did mine too
did you remember to add in the perches, tender springs, couplers and compare shock weights?
in the end, it's probably a bit less savings, but it's there
Yes, the coilovers were complete including external canisters, ready to bolt in.
ok - i could have sworn it was less, but i went back and checked my data, and sure enough 9-10lbs
Last Post by DaveN
02-07-2012, 02:41 PM
Last Post by gbarrier
04-25-2011, 09:02 PM
Last Post by Torbjorn968
04-10-2009, 05:29 PM
Last Post by Fox944
12-02-2008, 09:28 PM
12-01-2007, 06:04 PM
