Hey Bomb,
Nope...tires were replaced as soon as the car was running. D1r Braces are installed...Castor and Strut tower with the firewall brace.
All shocks and struts are original as far as I know. Only 44 k on the car, so probably still good, but I may swap them out. I can get factory OEM's from sunset for around $900 for all four corners.
Not sure what corner balance is but I am not switching to a M030 setup. I just want to car to handle properly. It should be good on a straightaway at 130MPH, but I can't get to 95 without the car getting all mushy and wandering up front...It just feels squirrley and I don't trust it.
We got to looking at the car, and others here mentioned it when I posted the photos, that the rear end looked a bit low. I will try to go and measure the ride height tomorrow.
If I can get my ride height even with a slight torsion bar adjust and new rear shocks, I will probably be satisfied. Then I will have it aligned.
I don't have many miles on the car yet, less than 200 but I may switch out tires. I think either upgrading to the Michelin Super Sports or the Yoko's I was on the fence about. I think some of it might be the chevron tire tread.
Flash, I just want to car to handle stock like it is supposed to. I don't want to lower the car as that throws everything off and I don't want to deal...When I did my volvo, I lowered a bit, but only an inch for a bit of cosmetic looks.
