05-20-2007, 10:50 PM
Well, since I finally got the clutch and related hydraulics completed (except for pressure testing and bleeding), I decided to plunge into the M030 Bar upgrade.
Jeff at Sunset Porsche had shipped me the complete kit, and it was truly complete! Love it when a plan comes together!
The front bar was really a piece of cake... just watch out when you are pulling it or putting the new one in postion, cause they are HEAVY! Good way to lose some teeth!
Getting the Rear Body Brackets around the new Bushing, and bolting them up takes some finagling... I finally got the best result by starting the top bolts into each bracket base, snugging them up, and using a ViseGrip as a clamp to pull the bottom of the bracket close enough to start the bottom bolt.
Then I backed off the top bolts and made sure the Bar was centered, and retorqued everything. I used adjustable heim joint Drop Links on the Rear Bar, so those took a bit of try and fit, but no real issue. Starting with the Drop Links set to the middle hole, and then I will go from there, depending on how the car feels.
Oh, boy! May be ready to install the Bilstein Escort Cup Coilovers any day! Or NOT!!! I'm still thinking about it...
