[quote name='Jim Child' post='29085' date='Dec 15 2006, 07:43 AM']If you stiffen the rear shocks and leave the fronts unchanged, then you would expect the car to demonstrate more oversteer. I wouldn't call it "hopping", but you would expect the tail to step out more easily. I like my race car to oversteer a bit, so I usually run my rear LEDA's stiffer in the rear. If the rear is literally hopping up and down then something else is going on in the suspension, probably with the bushings. I suppose its also possible you could have something strange going on with your tires. What sizes are you running and what condition are they in? Are they the same age, make and model all around?
Regarding changing direction too easily that sounds like a toe issue. What is your toe setting? Is this strictly a street car, or does it see track duty? People who track their 968's like the toe set at zero, or slightly out. This makes the car turn in better. The compromise is that it can make the car darty and annoying to drive on the street. Setting the toe slightly in will cure the problem you describe.
Hope this helps.[/quote]
Hi Jim
Sorry for the late reply, been a bit ill, as of what i use the car for its purely street use, as of the toe setting i will try and find the reading, however i believe its set at zero, if it is what setting would you recommend me going to?
As of the tyre issue, they are all the same age and type, size 225 front 245 rear, standard cs size, tread depths ok as well, however i have suspected the tyres for a while as i ran 18 inch which michelins on, tyres seemed better, but car tram linned alot as the offset of the wheels where different.
I think the toe is what i should try first, as the car does feel darty,
Thanks again for all the advice.
Simon
