well, try as we might we couldn't get the pilot bearing off the flywheel. We rented a bearing puller from Kragen, but there wasn't enough clearance for the tool to get seated.
Tried pushing a bolt through the center, hooking it on the back end with the head of the bolt, then pulling on the bolt with vicegrips, but couldn't get enough force.
So the flywheel came off so we could get the pilot bearing out. And. . . two stuck cheesehead bolts on the flywheel took a half day of persuading.
Now the flywheel is off, new pilot bearing will go back on.
Paragon sent me a replacement rear main seal - I dont have a leak back there - do you think I should do it? I am concerned about introducing a leak with less-than-perfect installation.
