Threads: 224
Drop by and try cycling through the gears yourself. Start with the car off. Might give you some clues.
Threads: 77
Sounds steep to me, it shouldn't be much more the two hours for removal and re installation (not including the rebuild). I have seen cheaper prices for rebuilding the transmission then that. You probably only need a couple parts in the transmission replaced, there wouldn't be any reason to replace everything in the transmission if it's just a 1/2 issue. Of course a shop would probably charge a whole lot more then two hours for the removal/instalation since it sounds like a bigger job then it is.
