Front sway bar drop links -- how tight?
Hello all -- I am new to the list (1st post). I bought my '95 968 Coupe w/ M030 in March and have been lurking on this list since. Since buying the car I have added a KLA strut brace, Mintex C-Tech racing pads, did a wheel alignment for the track, and last night (9:30PM-3AM) I installed Racer's Edge rear and front sway bar delrin bushing kits. My question is...after reinstalling the front sway bar, how much do I tighten the nuts on the front sway bar drop links? Any help / guidance would be appreciated. I am leaving this afternoon for Roebling Road Raceway in Savannah for a weekend DE and would like to know that the front bar is properly installed.
Thanks,
Mike (in Orlando -- but not MikeO)
Current P-cars:
'95 968 Coupe Black w/M030
'91 944 S2 Coupe White
Former P-cars:
'02 Boxster S Lapis Blue/Savannah Beige
'93 911 RS America Red
'88 944 Turbo S White
'84 944 Burgundy
'77 924 Gold
93 911 C2 Coupe
i wish i knew you were going to do that - i have a mod that i am working on a DIY for to fix the design problem in the racer's edge bushings - too late now, but i'll get to it when i get back from cancun so you can fix the problem you are about to have
the problem is that with teh delrin, the sway bar walk from left to right - this changes the preload from side to side, making for some interesting handling issues
drive it this weekend, but don't freak out when you take a turn and it feels different than the last time you took it
the fix is easy, but you need to order something from MSC that will take a week to get to you
as for tightening the end links - i snug them down until they hit about 35# - just make sure you aren't pulling the sway bar down as you tighten it (that would create preload), and tighten them with the car resting on its weight
Thanks flash for the reply....The walking sway bar sounds a little scary. Is the friction enough that the rubber bushings don't have this problem?
Mike
93 911 C2 Coupe
exactly - i have the fix though, and it's been working very well - no noises in the bushings, and they stay put - silent and solid for over a year now
i'll be in there for a different mod when i get back from cancun on the 8th, and can take shots and post a DIY on the swaybar fix
have fun this weekend - shiny side up
The M030 front bars have circlips that go on the ends which prevents some lateral movement. You could always put metal collars on the bar itself like the Tarrett bar has.
Eric
Last Post by Roboman
10-02-2020, 11:24 PM
02-01-2020, 12:42 PM
Last Post by gbarrier
06-10-2018, 01:03 PM
Last Post by MCL968
08-01-2017, 02:23 PM
Last Post by az968
06-15-2016, 12:45 AM
Last Post by N_CA
03-17-2016, 04:20 PM
