Threads: 49
Does anyone out there know if the 968 strut has a threaded cap on the top of the strut tube? The Bilsteins that are available have threaded collars which are supposed to (according to a bunch of sellers) fit the 968 strut. I have never been a big Koni fan, so I would like to go with the Bilstein B6, providing it will work on a 92 968 strut. The rears look like they are a standard replacement part.
1992 968 Cabriolet
Volvo S60 Turbo AWD
Lexus RX 300 AWD
Threads: 51
I did the Koni insert conversion to the stock 968 strut a few years back and I don't recall there being any threaded section. In the conversion the top is cut off the existing unit to gain access for the new insert.
87 944S
19 Audi A6 3.0T
03 Toyota Tundra
Threads: 51
87 944S
19 Audi A6 3.0T
03 Toyota Tundra
Threads: 45
If you are going B6
You will need to hack 42mm off the top of the strut, empty the guts in a bucket, then weld a collar into the top of the strut
you can buy some BMW motor cycle exhaust nuts that fit, Motorrad 0641702141921 they are about $10 each.
drill the top of the strut case and plug weld in four places then seam weld the tops
insert strut, do up nut thats in the box, fit bellows, no need for bump stops they are built into the insert
re-geo and away you go
done five sets of struts now
1986 Honda VF1000 FII
2016 Volvo XC90 D5 R-Design
Threads: 49
Thanks Waylander, that's great information.
Is there a reason that someone doesn't just thread the strut with a M50 x 1.5 die nut? That would seem to be the easiest solution, unless the strut is too short and the insert requires a threaded collar to add length to the strut tube.
I wonder if those exhaust nuts are available on my side of the pond?
Matt
1992 968 Cabriolet
Volvo S60 Turbo AWD
Lexus RX 300 AWD
Threads: 45
(This post was last modified: 06-01-2018, 12:46 PM by
Waylander.)
Threads: 45
