I got responses from both Chris at 944 enhancement and Mike from Lindsey Racing. They cleared everything up for me. Here's what they had to say.
Chris:
Welcome to the fun would of 944/968 rebuilds! Not a lot of info out there and a pretty good chunk of it is wrong.
First thing is to clear up some wording – the cylinders are not sleeves – that term is usually used for a different material (usually steel) inserted as a wear surface. The 944/968 blocks are one casting of Alusil. The final step in finishing them is not really a honing process in the traditional way, is a chemical/abrasive process that erodes the aluminum away and leaves the silicon exposed as the wear surface. Not very common and its hard to find a good shop that does this process. It takes the right felt ‘stones’ and the right chemicals. BMW and Mercedes have used a similar system so look for a shop that specialized in high end euro stuff.
The bearing clearances are pretty typical – the mains are set like most aluminum blocks and the rods are set a little tighter (no problems with aluminum expansion). Stick towards the lower end of the ‘play’ spec and you will be OK.
I would also recommend getting your bearings coated for a little extra protection. Check out Calico Coatings.
Good luck!
Chris White
944 Enhancement
Mike:
Hello Jon,
Dave asked me to answer your questions, I take care of most of the engine related questions here at LR. For starters, these engines do not have sleeves. The blocks are what is called an Alusil material, this is a silicon impregnated aluminum alloy. It required use of very specific honing tools to properly do the job, you cannot use the conventional stones like you would on a steel sleeve or cast iron block. The machine shop we use here locally uses the Sunnen equipment. I would have the cylinder bores measured by a professional with a dial bore gauge, if the cylinders are within tolerance and visually look to be in good condition, it is not necessary to hone the bores. We have simply cleaned the bores really well, oil them up and install the pistons with new rings. What ever you do, don't use one of those glaze breakers or hone stones. Those will ruin the cylinder walls and require boring to a larger size the clean them back up.
As far as the rod and main bearing clearances go, I find that most of the engines we have built come in around .002" or .05mm clearance. I personally do not like to see an engine run too tight of a clearance, you need to have a good amount of clearance to allow for good flow of the oil.
Matching oil viscosity to engine clearances is important. If all of the engine clearances were tight, at the minimum of the tolerance, then you could run a light weight oil, such as a 10w-40. I prefer to see clearances a little greater, like I said in the .002" range, this allows you to run a thicker 15-50 viscosity oil. Running too light of an oil with larger clearances will definitely lead to troubles.
Another thing to check when you build this engine is the side clearance on the connecting rods. Porsche typically runs a very tight side clearance, that is fine for normal street use, but if you intend to do autocross or drivers ed events, then you need more clearance. This will allow for more oil flow through the bearings and help to keep them cool under the constant high rpm conditions.
I hope that helps
Regards
Mike Lindsey
Lindsey Racing
I also found a thread on Pelican Parts about re-ringing Alusil cylinders. It's pretty long, but there's some good information in there.
Re-ring Alusils?
