06-01-2013, 04:49 PM
Car background:
Car issues I need to address:
Belts
Engine reseal
Cooling Systems
My goal here is to bring my car back up to spec to support my daily drive. Which is only ~10miles per day.
I love my car and am willing to invest (reasonably) to keep it running well.
The cooling system is most risky so I plan to get that sorted in the next week. But thinking everything else might be best done at the same time: belts, and engine.
So my question to the forum is:
Thanks!
/Mike
- I have a 92 Coupe. 105k miles.
- Bought from reputable p-car company (Weissach) who addressed everything needed at 73k miles
- Car is my daily driver, no issues. Not a track car
- Generally well maintained, by mechanic. I only do minor stuff myself mostly due to time
Belts
- All belts were replaced when I acquired that car at 73k miles (7 yrs ago).
- Conclusion: It's time to get my timing belts done.
Engine reseal
- Oil consumption has steadily increased over last year. I have wet oil and carbon build up on spark plugs.
- Engine has never been rebuilt AFAIK
- My mechanic says this is due to oil leaking into the combustion chamber.
- Mechanic is recommending - front end reseal, lower balance shaft housing seal, rear main seal, new engine mounts
- Estimated as 12hrs labor + parts
- Conclusion: Yeah I think I need to do this. For now I add 1qrt of oil every week and change my plugs more often then I should
Cooling Systems
- I could start a separate thread on this one...
- I have been running hotter than I should, and have a slow leak in the cooling system.
- Through process of illumination I have concluded I have a leaking water pump that I need to replace
- Conclusion: I am on borrowed time and need to fix this one ASAP.
- What do you think of my mechanics' recommendation on the engine?
- Assuming I get the engine work done, what other things should I do while in there (considering my goals of daily driver)
Thanks!
/Mike
