07-19-2018, 01:41 PM
I have been meaning to post this for a long time now, but here it is:
Filter and Fluid Service:
<p style="font-family:Helvetica;">The service interval for the Filter and Fluid is 3 years or 50k miles, whichever comes first. If you have not serviced your system within that period, you are now overdue. If your fluid in your reservoir is not blue (i.e. black) it is overdue.
<p style="font-family:Helvetica;">Note: Use ONLY Rotrex filter and Traction Fluid
<p style="font-family:Helvetica;">Note: The proper method of checking your fluid level is with the engine FULLY warmed up, and at idle.
<p style="font-family:Helvetica;">Belt Service:
<p style="font-family:Helvetica;">The belt should be replaced as a standard service item in not less than 3 years. It should also be replaced at the time of an engine timing belt project, or any time it is "relaxed" as a part of any service. Never re-use and/or re-tension the double sided Drive Belt if it has been used for more than 1000 miles.
<p style="font-family:Helvetica;">Replacement parts:
<p style="font-family:Helvetica;"> Upper Idler Pulleys
<p style="font-family:Helvetica;"> Supplier: Dayco
<p style="font-family:Helvetica;"> Part Number: 89095
<p style="font-family:Helvetica;"> Service Notes:
<p style="font-family:Helvetica;"> 1. Shave .035" from the face of the pulley with the dots on it (not the side with the printing)
<p style="font-family:Helvetica;"> 2. Install shaved side toward mounting plate
<p style="font-family:Helvetica;"> Lower Idler Pulley
<p style="font-family:Helvetica;"> Supplier: Jackson Racing
<p style="font-family:Helvetica;"> Part Number: 2" Steel Pulley
<p style="font-family:Helvetica;"> Double-Sided Drive Belt
<p style="font-family:Helvetica;"> Supplier: Gates
<p style="font-family:Helvetica;"> Part Number: DK060674
<p style="font-family:Helvetica;"> Filter
<p style="font-family:Helvetica;"> Part: Rotrex Filter
<p style="font-family:Helvetica;"> Fluid:
<p style="font-family:Helvetica;"> Part: Rotrex Traction Fluid
<p style="font-family:Helvetica;">The Double-Sided Drive Belt and Upper Idler Pulleys can be sourced locally, and on Amazon.
<p style="font-family:Helvetica;">Jackson Racing can be contacted at:
<p style="font-family:Helvetica;"> 5125 G St
<p style="font-family:Helvetica;"> Chino, CA 91710
<p style="font-family:Helvetica;"> info@jacksonracing.com
<p style="font-family:Helvetica;"> 909-927-8500
(This post was last modified: 07-19-2018, 01:43 PM by flash.)
