CS Steering wheel
#41
Another 930 wheel with the crest installed:
[Image: Interior.jpg]
Yeah, that 930 wheel is really a lovely mod.
Looks great! I like it as much as I do mine, good luck, Bob Blackwell.
Pics of yours Bob? <hint,hint!>
I was not able to post a picture to this site, so I sent you a message with it as an attachment. Bob blackwell.
I got it Bob. Thanks. I love the wheel, alot better then stock.
Yes, I have the AJ 930S wheel w/ the Porsche crest on my 88' 911 Cab, I do like that wheel.
One of the guys at Sunset told me the shaft size is diff. on the 968 which is why the spacer/adapter that works on the 911 will not work w/ this car. I'll see when I take the wheel off. I had to have the spacer for the 930S wheel on the '88 because my fingers nearly got pinched in the dash the wheel was so close (w/o the spacer).
On a side note, lovely day for a drive in the '88 911 with the top down today here in Nashville. As much as I would have liked finishing up the 968 and NOT having to go look at fabric swatches a nice brisk drive was just what the doctor ordered. We're expecting rain from Sun. night thru Tues sometime so we'll enjoy it while we can.
[quote name='Tigershark' date='Mar 16 2006, 10:11 AM']Pics of yours Bob?  <hint,hint!>
[right][post="17427"]<{POST_SNAPBACK}>[/post][/right][/quote]
Hey Tigershark dig your new avatar.
umm.. the wheel base is not fitting in the hub like it should. The turn signal clicker thing does not fit where the OEM does. This is the wheel that Eric is talking about in the first post... would like to put it on but doesn't look like it will work.
BTW.. my car is leak free and i drove approx 100 trouble-free miles since i got it back. <img src="/forum/images/smilies/968/laugh.gif" class="smilie" alt="" /> <img src="/forum/images/smilies/968/laugh.gif" class="smilie" alt="" /> <img src="/forum/images/smilies/968/laugh.gif" class="smilie" alt="" />
I don't want to put the OEM wheel back.. what should i do?
Order the adapter from cargraphics, that is what I did to get mine to fit. Good luck, Bob Blackwell.
[quote name='bob blackwell' date='Apr 11 2006, 03:27 PM']Order the adapter from cargraphics, that is what I did to get mine to fit.  Good luck, Bob Blackwell.
[right][post="18950"]<{POST_SNAPBACK}>[/post][/right][/quote]
What's the adapter called? Is there a part number? Perhaps a link to the product. Thanks.
Sorry, looking through all my receipts I cannot find it. I just ordered the adapter to mount the 930S steering wheel to the 968 shaft. I can't find the website anymore either. Good luck, Bob Blackwell.
[quote name='bob blackwell' date='Apr 11 2006, 07:22 PM']Sorry, looking through all my receipts I cannot find it.  I just ordered the adapter to mount the 930S steering wheel to the 968 shaft.  I can't find the website anymore either.  Good luck, Bob Blackwell.
[right][post="18977"]<{POST_SNAPBACK}>[/post][/right][/quote]
OK.. the hub i have still is about 1/4 off ... it seemed like it would fit... but too snugly. I couldn't turn the wheel without the whole turn signal/cruse housing turing also. Perhaps i'll acquire one of those other hubs...
I connected my old steering wheel back and the idiot and air bag light are on.. Everything is connected like it was prior to installation. Is there a way to reset the system other than disconnecting the battery?
Only way for me was to have my PM reset with the hammer.
[quote name='SILVY968' date='Apr 11 2006, 11:29 PM']Only way for me was to have my PM reset with the hammer.
[right][post="18985"]<{POST_SNAPBACK}>[/post][/right][/quote]
sh*t.. well i guess i'll have to live with it till i get back from vacation this weekend... perhaps they can sneak me in tomorrow or thursday?
I got a hammer i can reset it with. Probably won't work as well though. <img src="/forum/images/smilies/968/laugh.gif" class="smilie" alt="" />
Yeah, the old "bigger hammer: theory of maintenance "if it don't fit, get a bigger hammer....." is very tempting sometimes. To be avoided at all costs around Porsche cars. Good luck, Bob Blackwell.
After installation several months ago I am getting a rubbing sound when I turn the wheel. It comes from the plastic dress piece, with the round hole in it, under the steering wheel, rubbing on the steering wheel adapter hub. It is as if the steering column has shifted relative to the plastic dress piece.
Is the steering column jacket tube attached at another point in the body that may be loose? I also notice that when I lock the wheel when parking, the ignition key moves about 3/8" when I the wheel to unlock it. I know that they are connected thru the steering lock housing, but should there be noticable movement?
The steering lock housing attaches to the car with 2 SHEAR BOLTS. Could these be loose and cause the slight off center problem? If I try to tighten them will they shear off and require drilling to remove them?
Any ideas? or has anyone had a similar problem?
I'll pull it apart this weekend and look around.
After I installed my 996 wheel, I had a similar rubbing. It was cured by removing the wheel and cutting a little bit off the four mounting studs of that plastic piece. That moved the piece a little closer to the instrument cluster and away from the wheel, and it no longer was rubbed by the wheel.
Anchorman,
Thanks for the tip, I'll try that this weekend.
Brian
Anchorman,
It did the trick.
Thanks for the insight.
Happy Father's Day to all that it applies to.
Last Post by ryker
08-25-2013, 10:58 PM
08-21-2013, 09:19 PM
Last Post by DaveN
03-11-2013, 03:33 PM
10-28-2012, 09:12 PM
Last Post by Gotter
03-02-2012, 04:29 PM
Last Post by MC968CS
01-12-2012, 06:29 AM
Last Post by bombfactory
10-25-2011, 02:05 PM
