10-28-2013, 09:23 PM
Do you want your car to go from looking like this:
![[Image: tn_DSC_4465.JPG]](http://www.audipages.com/968/tn_DSC_4465.JPG)
To something more like this?
![[Image: tn_IMG_3127.JPG]](http://www.audipages.com/968/tn_IMG_3127.JPG)
If so, this post is for you!
I know, it's iconic that I am posting a thread on how to retrofit a new steering wheel to my 20 year old car, but I haven't seen one in detail on the web. So why not?
First, you need to find yourself some new shiny for mounting on the steering hub. I initially choose a 4 spoke 993 steering wheel, but then found this 3 spoke alcantara wrapped wheel from a 993 GT3. I scored it very cheaply relatively speaking and I also found out that my four spoke wheel was actually MODIFIED by the previous owner (he forgot to mention this) and it would not fit a 968. A 4 spoke 993 wheel with airbag will run you $200-$350, a three spoke is more like $400 and up.
Once you find the steering wheel, you need a clock spring from a 964, 993 or 996, you can find them all over ebay for anywhere from $35 to $100. The part number I purchased was 996.652.211.00. The nice thing about this clock spring is that when it is removed from the car, you can't "unwind" it because of the spring loaded locking pin. I will discuss how to set it up later in the procedure, it's pretty much fool proof.
![[Image: tn_DSC_4494.JPG]](http://www.audipages.com/968/tn_DSC_4494.JPG)
![[Image: tn_DSC_4495.JPG]](http://www.audipages.com/968/tn_DSC_4495.JPG)
![[Image: tn_DSC_4496.JPG]](http://www.audipages.com/968/tn_DSC_4496.JPG)
Things that you will need include:
- Steering Wheel
- Clock Spring
- Length of 16 gage wire about 20" long
- Insulation Displacement Connector
- Dremel Tool
- Torx T30 to Remove/Install Airbag
- 7/8" or Equivalent Metric Socket
- Various Basic Tools
