10-13-2015, 09:33 AM
A week ago I drove the car out of town, 250 miles each way, drove it around over weekend and drove it back to Madison with not a single problem or drop of coolant that I noticed. But the moment i pulled up into the driveway at home there was a flood of coolant , at least several hundred ml or so, that appeared to be coming from the expansion tank.
After washing the car I pulled into the garage where it has sat for over a week now. Just this morning I checked the expansion tank and it seemed almost full. When I unscrewed the cap there was enough pressure to raise the level up and overflow around the cap.
Got to be lots of air getting in the system somehow, right?
Oil level on the dipstick is perfect and where i left it. Oil looks fine, not milky or anything like that but I'm concerned.
Is there supposed to be a O ring or gasket around the bleeder screw?
Earlier this summer I took great pains to bleed the system with the front of the car slightly higher than the rear, engine running at a high idle, bleeder screw removed and a small recirculation hose fitted that transferred the escaping bubbles and coolant back into the expansion tank. Ran the car this way for over 20 minutes on the driveway. Maybe that trick didn't work?
Any ideas?
--Michael
Any ideas?
--Michael
