control arm in, belt out
More fun. Took the car in for the scheduled 24,000 km service (car has about 320,000 km now) to have the control arm replaced to deal with a failed ball joint. After the alignment the belt was chirping a bit. So they decided to see if it needed some tightening (it was tightened a bit a while ago). Discovered that one of the bolts holding the A/C compressor was failed and the belt was trying to walk itself right off the pulley. Also discovered a torn rear axle boot. Always good to get next year's projects planned before the current year is over.
Failure of an A/C compressor mounting bolt is, in my personal experience, all too common. I must have had at least three such failures - including one while on the track at Watkins Glen. I've also had an A/C compressor mounting lug fail. You can imagine that I've thought more than once about getting rid of A/C altogether.
So have I. But, when you drive it for long distances at a time and drive it a lot (37,000 km so far this year), roasting my arse doesn't seem all that appealing.
That's exactly why I've thought about it, but haven't done it. Since I purchased a winter car (a 2004 PT Cruiser two years ago), the mileage I'm putting on the 968 has dropped dramatically - but I've still put an annual average of nearly 20,000 miles on it over the six-and-a-half years I've owned it.
Got it back today. One bolt was broken and the other bent. Put on a new belt and all is good now. I also had the gear oil changed out at the same time. What a friggin' difference THAT made. I shifted into second coming from the repair shop lot and thought that something had come off as I went through neutral from first. Wow. The other stuff was only 2 years old.
<!--quoteo(post=81263:date=Oct 5 2009, 04:58 PM:name=Kim)-->QUOTE (Kim @ Oct 5 2009, 04:58 PM) <{POST_SNAPBACK}><!--quotec-->Got it back today. One bolt was broken and the other bent. Put on a new belt and all is good now. I also had the gear oil changed out at the same time. What a friggin' difference THAT made. I shifted into second coming from the repair shop lot and thought that something had come off as I went through neutral from first. Wow. The other stuff was only 2 years old.<!--QuoteEnd--><!--QuoteEEnd-->
What gear oil did you change to?
Brian
Mobil 1 75W90, whatever Porsche uses at the shop.
06-25-2022, 04:42 AM
Last Post by Bulti
05-07-2017, 04:27 PM
Last Post by TonyBray
03-05-2009, 12:06 PM
04-01-2008, 10:05 AM
Last Post by Spieln968
02-16-2005, 01:20 AM
