Clutch pedal went down and stayed there
One theory is that a new hose = more pressure to the old cylinders.
In response to Mbardeen's question about the clutch pedal, that sounds like it could be a separated firewall. Mine was acting just like that before I put a support bracket on the master cylinder. My firewall had completely separated, causing the master cylinder to move and affecting the geometry of the pedal pivoting, which gave it this two-stage over-center feel.
+1. I had my hose go, then the slave went afterward. There is no way to tell, but age catches up with you. I doubt the book says 4 hrs to replace the hose. Replacing slave is easy though, very accessible. Bleeding can be a chore.
The clutch hose on these cars seems like it is a very common issue. Curious if other cars of this age have similar issues??
2005 Acura RL
2004 Toyota Sequoia
Last Post by Ernie
12-17-2019, 11:34 PM
Last Post by Sculler
09-20-2016, 11:23 PM
Last Post by Bulti
08-30-2016, 01:12 AM
