[quote name='flash' timestamp='1327632473' post='120975']
the problem with dave's was an unseated slave clevis rod - PorscheG96 was on it minutes after me. we were both on the same thought.
I think mine may have this issue at the moment, as I had to remove the slave cylinder as part of the clutch removal job. The slave clevis rod (I assume this is the name for the rod the protrudes out of the nose of the slave cylinder) feels like it isn't attached to anything - just sort of flopping in the breeze. I tried briefly to push it back into position, but it wasn't popping in easily, so I didn't pursue it, realizing it would probably be months before I had to put the slave cylinder back. Is there a trick to re-seating the clevis rod? Thanks.
