Threads: 15
After having the AP 2500 lb. clutch kit sourced through Pete installed last month, I can report that pedal effort is greatly reduced over the Sachs 3100 lb. unit that was in the car when I bought it. Flash would probably hate the feel, as engagement is a bit soft, even for my taste, but operation is nice and smooth with all new components everywhere in there. Perhaps I need to bleed the hydraulics or just drive it more and wear it in to get the clamping to feel a bit more positive? (car is down with a bad hall sender right now)
-Austin
'94 Black/Tan Coupe
(This post was last modified: 04-19-2012, 01:44 PM by
bombfactory.)
Threads: 19
Just a couple of weeks ago when I looked at the latest Sachs catalog, it showed pressure plate 3082 213 133 as part of Porsche Repair Kit Part # 968-116-911-00
'92 Midnight Blue 968 Coupe
Threads: 19
It's the one I'm planning to use (the blue strip -133 that is). I just removed the no stripe -132 part which was waay too stiff. My PGT feels like butter compared to the -132 part, and the PGT clutch will hold up to 350 hp at the wheels. If I really don't like the feel, the 968 clutch is soo easy to replace I'll switch to something else then. I like the feel of Eric K's clutch which is not a Sachs unit. And, I know from the class he runs he has ~300 at the wheels. So, his choice is another candidate if I don't like the feel of the -133. And, I can have both for no more than I'd spend for the -131.
Threads: 19
[quote name='flash' timestamp='1334870297' post='125696']
no luck - the warehouse won't pull the part without me buying it.
I'll be a while before I'm at Sunset again, but I'll talk to the Parts Manager to see if he can help us with the warehouse.
Threads: 49
OK, here we go again... I contacted Sunset, they gave me the part number 968 116 911 00, This is for the complete clutch kit. I found the same kit at a local supplier (EBS Racing) here in Reno. I went down there today and Jim was kind enough to pull the kit for me so I could check out the pressure plate.
It has a BLUE stripe!
The casting shows TYP GMFZ 240 Sachs 3032 125 199
It is STAMPED T38 10 3082 213 133
So, I am guessing, in spite of the same part number, the BLUE stripe and the 3082 213 133 indicate that it is the WRONG plate.
Any suggestions or advice?
1992 968 Cabriolet
Volvo S60 Turbo AWD
Lexus RX 300 AWD
