Threads: 24
Hi,
Today I installed the cat-back system from Cargraphic on my car, it makes a difference performance wise as it improves the sound...just some pictures to share....The car is now running with the stock exhaust manifold & Cat. The resonator has been replaced by two pipes, which run all the way up to the rear muffler.
1992 Amazon green convertible. Cargraphic cat. back exhaust, RS Barn/ Design 1 Racing lower & upper strut brace, RS Barn stage 1 Chip, Airbox modification, M030 Swaybars.
Threads: 31
Very nice, glad you finally got it installed.
Threads: 24
I will try to crawl under the car and make a picture this weekend..... <img src="/forum/images/smilies/968/unsure.gif" class="smilie" alt="" />
Threads: 24
[quote name='968norway' post='38190' date='Jul 13 2007, 09:03 AM']I recently installed the full Cargraphic exhaust, with the mid-box. Can report a noticeably deeper note, more of a growl. Definitely an improvement over standard.
Have you gone to the cargraphic.de website? You can see it there.[/quote]
Did you also replace the Cat?? I am afraid if I will change the Cat to a sport Cat I am loosing to much back presure, because I do not have the mid box anymore.....
