Threads: 5
Did the dealer loosen the tension on the balance belt to align the lower balance shaft? If so they should have reset it to the correct tension. If it is open and the tools are available I would check the tension.
[quote name='jaap' date='Oct 11 2005, 08:52 AM']The dealer realigned the balance belt which they say looked good which was also my impression from my first inspection. I assume I don not need to have this belt tension checked again because it was already broken in?
Jaap
[right][post="11050"]<{POST_SNAPBACK}>[/post][/right][/quote]
