antenna wire
Has anyone replaced the anttenna coax cable, how much interior trim must be removed, or do you know the routing direction etc. I hate trim work so removing as little as possible is my goal.....thanks.
Amen! With that gruesome glue these slather all over everthing, taking trim loose is a messy undertaking.
I also have a new antenna ready to go in and looking forward (?) to finding out how much stuff to disrupt ...
[quote name='Tom in Austin' date='Mar 10 2006, 03:05 PM']Amen! With that gruesome glue these slather all over everthing, taking trim loose is a messy undertaking.
[right][post="17176"]<{POST_SNAPBACK}>[/post][/right][/quote]
I'm working on it right now, I'll let you know...
Antenna replacement is not too tough. I've attached the page from the manual that lays it all out.
One note. You need a very deep well open socket to remove the nut holding the antenna in place (while respecting the coax antenna cable). Use the lug nut socket from your onboard tool kit. It is perfect for the job.
If you're considering replacing the coax from the radio to the antenna connection, you're on your own with my sympathy.
[quote name='Dilbertnomore' date='Mar 10 2006, 08:11 PM']Antenna replacement is not too tough. I've attached the page from the manual that lays it all out.
[right][post="17186"]<{POST_SNAPBACK}>[/post][/right][/quote]
Yes, the antenna comes off easy, its the coax that's a hassle. I just rerouted the new wire, as to pull the original out was going to require a lot of hassle. It must have a number of tie downs and other obstructions, I could not pull it at all. The way I have it now it is completely hidden.
Hey Frank, how did you route the new coax cable exactly? Any helpful tips? I certainly appreciate your point about not bothering to root out all the fasteners on the original cable ...
[quote name='Tom in Austin' date='Mar 14 2006, 09:23 AM']Hey Frank, how did you route the new coax cable exactly? Any helpful tips? I certainly appreciate your point about not bothering to root out all the fasteners on the original cable ...
[right][post="17328"]<{POST_SNAPBACK}>[/post][/right][/quote]
I routed it under the headliner (under the trim panel you first need to remove to access the antenna) where the original wire runs then snaked it down the the pass side where the interior trim panel is, (behind the part that has the rear seat locking device and seat belt retainer).....then lifted the carpet molding at the passenger entrance, tucked it in there then up under the dash along the evap case, tucked it behind the carpet etc.
The original would not budge, it must have a bunch of ties on it and I have a feeling it is run along the headliner on the passenger side, I did not want to search and have to remove the headliner.
The radio works great, the antenna amp must have been bad.
Last Post by xrad
07-19-2009, 09:11 AM
Last Post by Beachboy
03-29-2007, 08:23 PM
Last Post by KMR968Turbo
11-18-2006, 02:25 AM
Last Post by EEZATOY
10-07-2005, 11:51 AM
09-28-2005, 03:18 PM
