[quote name='tamathumper' timestamp='1342465656' post='129449']
I've searched the forum, other forums, and the workshop manual, and I can't find a particular spec for the power steering and serpentine A/C-alternator belts, other than a very general "5mm of deflection on the longest span with moderate pressure" kind of description. That's so subjective as to be useless.
Tama, I think what Porsche is trying to tell us is that the setting isn't that critical. The bearings in all the components on our cars should be able to withstand way more force than the hundreds of pounds of tension even if you're way over the spec. The belt tension is more for belt life, and to insure there is enough "grip" of the belt to drive the expected loads.
For reference , my Mazda engine has a similar spec. albeit a bit more specific. The alternator/A/c belt has a similar span between the crank pully and the A/C compressor of about 10 inches and similar pulley diameters. It is a 5 rib, rather than the 6 rib that is on the 968. The Mazda spec calls for 10Kg/22lbs of force applied mid span and a corresponding deflection of 6mm +/-.5mm for a new belt (corresponds to 160 - 190 lbs of belt tension), 7mm +/- for a used belt (corresponds to 110 - 150 lbs of belt tension), with a limit of deflection of 8 mm (99 lbs mimimum). The belts are to be measured with the engine cold, or after it has been stopped for at least 30 min. Since our belt is a 6 rib, I can see the spec. being 5mm deflection that you mention above, for a similar load of 10Kg/22lbs. I have a small push spring scale that I've used for years to set belts this way, measuring the deflection by laying a straightedge over the pulleys.
You can see from the large range that is "OK" on my Mazda, the belt tension isn't all that critical.
