Trailing Arm diagram
Excellent! This will come in handy!
Awesome! Thank you for the breakdown.
Stephen
Black '95 968 Cab
Previously: '79 924, '84 944, '85.5 944, '94 968
I have a question about the drawing above: could it be that the toe and camber adjusters are switched? Because the P221 tool is used to adjust the toe and it goes into the hole where it says 'camber adjust'.
Or am I missing something?
You are correct, they are switched in the drawing. The stud that the sway bar drop link mounts to is used to adjust the camber, and tool P221 goes in the empty hole to adjust the toe
Thanks for confirming!
06-25-2022, 04:42 AM
Last Post by Kim
10-06-2009, 07:36 PM
Last Post by TonyBray
03-05-2009, 12:06 PM
04-01-2008, 10:05 AM
Last Post by Spieln968
02-16-2005, 01:20 AM
