Parts are finding their way to my doorstep.
Regarding the clutch/bell housing: looks like the late 944, 951 and S2 housing are the same. The 944 flywheel is a little different than S2 flywheel. However, the S2 flywheel is the same as 968 in regards to the stepped sensor blocks and the 968 and S2 use the same flywheel position sensor. These will work with the Haltech.
I decided to go with the 944 S2 steel flywheel for several reasons:
1) it fits the smaller housing
2) they are available
3) being steel, I feel more comfortable with the higher clamping pressure plate forces on the screw threads
4) weight: stock is ~16lbs (from what I can find) this puts it right where I want it weight wise. Some lightened turbo 944 flys are as low as 10lbs and less.
6) there are at least 3 brands of increased clamping pressure plates available (steel) and one aluminum plate (and just as many choices of discs)
or I could go with a late 944 flywheel, have the same options, just have to change the sensor.....
BUT, you can not use the 968 flywheel in the 944 housing (as stated in other posts..and vice versa). This is for several reasons. The flywheel is thicker and holds the ring gear. Different throwout mechanism? and Ring gear is located on the pressure plate for S2 and 951, and 944. So it just won;t fit.
Whay am I not using the stock 968 flywheel and housing. Well, I could. And it has been done before with turbo conversions. But:
1) i want more room for wastegate
2) exhaust not right up against starter
3) the general availability of 944, 951, S2 cltuch parts form many vendors at reasonable rates
BUT remember, if you convert the clutch housing from 968 to 944 style, you will need the longer torque tube from a 951 or S2. As stated above, i was able to locate one with only 29,000 miles on it. There are plenty of these around and you can now get aluminum spacers and bearings for them.
http://cgi.ebay.com/ebaymotors/Porsche-944...emZ170265853684
here is the bell housing rebuild kit:
http://www.lindseyracing.com/mm5/merchant....e=944CLUTCHMISC
Starter: You will have to use a 944/951/s2 starter with the 944/951/S2 bell housing. these are 80$ rebuilt.
So the plan for the clutch setup is S2 flywheel, higher pressure plate and disc (yet to be determined), 944 throwout bearing, bellhousing rebuild kit 944/951
