Threads: 35
I bought my '92 cab with just under 60K miles. I don't have any service history (but I did take it for a pre-purchase inspection). I'm going to have the timing belt replaced and whatever else is called for at that maintenance interval. I have read where some people recommend replacing the water pump at the same time and also balance shaft belts.
My water pump shows no signs of leaking. Should I replace it anyway? I don't even know what balance shaft belts are...
Appreciate any opinions on how far I should go beyond the standard service.
Thanks,
Greg
Greg
'92 cab. Guards Red/Black.
Threads: 15
Balance shaft belt should be done along with the timing belt - you can source a belt kit from Pelican, Paragon or Sunset Porsche. Consensus here is to go with Gates or Porsche belts, avoid Contitech. Water pump might need replacing due to age, if it's original.
-Austin
'94 Black/Tan Coupe
Threads: 35
Thanks for the advice. Sounds like I might as well start with a good solid (known) baseline.
Greg
Threads: 167
Front balance shaft seals are a known leak point. You should do those as a "while you're in there" fix.
Regards,
Threads: 35
Any strong feelings about new vs. rebuilt water pump?
Greg
Threads: 35
If it's OEM, can you be sure it's the right type of impeller?
Greg
Threads: 35
I am very much a "Rookie" in all things 968. This forum is great!
Greg
