AC question
Stupid question, I know, but where do you put freon in this thing? I've got a 92 model and there are multiple places that look to be "the one". Thanks.
You should do a search on A/C's but I know on my 93' the low side is on the compressor located at the bottom of the engine, you will have to remove the underside pans to get easy access to it. Be careful though you most likely have R12 and you cant add 134a to that or you will destroy it. Very expensive to fix. I really dint know much about A/C's but learned what I Had just mentioned by reading the different post. Be cautious
Yeah...mine does indeed have r12....I managed to get a hold of some.
Yes, low pressure side to recharge is on the underside...remove the belly pans and you'll see it fairly close to the compressor. Helps if you can get the car in the air.
- Darryl
Last Post by MCL968
11-12-2016, 03:06 AM
09-15-2012, 06:39 PM
Last Post by Lear35A
11-04-2011, 10:55 AM
Last Post by BeBe
10-10-2011, 10:20 PM
Last Post by 968workaholic
09-21-2007, 04:42 PM
Last Post by 968rz
05-01-2007, 05:35 PM
