AC Dryer question
I have a '92 which has been converted from R12 to R134. I blew a hose about two weeks ago so will need to replace the dryer as well. Do I use the one for 92? or for 93-95? or does it not matter?
I don't think it matters. When I changed my 944S to 134 I bought the dryer at Auto Zone for under $20.
87 944S
19 Audi A6 3.0T
03 Toyota Tundra
[quote name='pickwick' post='41521' date='Sep 21 2007, 08:26 AM']I have a '92 which has been converted from R12 to R134. I blew a hose about two weeks ago so will need to replace the dryer as well. Do I use the one for 92? or for 93-95? or does it not matter?[/quote]
The dryer is different on the 92. The 93 and up have blocks that bolt to the top of the dryer and the 92 has a line that screws directly into the dryer. I would take a look at your dryer and see if you can tell if there are two blocks bolted on the top of it or not. If they are there then you would need the 93-up dryer. If not then the 92. Good luck
Last Post by MCL968
11-12-2016, 03:06 AM
09-15-2012, 06:39 PM
Last Post by Lear35A
11-04-2011, 10:55 AM
Last Post by BeBe
10-10-2011, 10:20 PM
Last Post by Darryl
07-11-2010, 07:37 PM
Last Post by 968rz
05-01-2007, 05:35 PM
