Threads: 23
Bought my current 968 ('92 cab) about a year ago and air had been blowing pretty cold until a few months back, then it slowly lost its 'chill'.
I figured, no problem, car was converted to 134a (according to the receipts) several years back. I've done recharges in the past, so no big deal.
Well, I bought some 134a and had my trusty guage/refill hose and fitting. But when I went to clamp it on to the low pressure fitting on the car, it didn't fit. It actually shot back out just a bit of the fluid that was in there.
Couple of questions for those that have had the conversion done.
1) Is it possible that they did the coversion, but left the old 'freon' fitting on there? And would this be standard procedure for doing the conversion?
2) The fluid that came out was green in color, not sure I've ever noticed the color of freon or 134a, but does the color give an indication of which fluid may have been in there?
3) If it was coverted (as indicated by receipts) to 134a, but still has the older freon fitting, anyone know if I can just buy the appropriate adapter for the 143a can to the freon fitting?
I may end up taking the car by an a/c specialist. I'm hoping they can quickly ascertain whether the car has been retrofitted, and the appropriate connector to use.
Any feedback appreciated.
Chris
'13 Lexus GX
'04 BMW 525
'92 968 Cab Black/Grey
Corvette Z06 - Dedicated track car (Sold)
'94 968 Cab-Guards Red (Sold)
Threads: 25
I never noticed a color difference in freon; they may have put a dye in the system to make leak checks easier.
The fitting/hose is not normally replaced but an adapter is installed, possible they took it off or got stuck on the gauges when removed.
I'm sure you can buy adapter kits but not sure where, I got a set when I bought an upgrade kit for the Trail Blazer (it had gauge, hose, adapters, freon and simple instructions) I got the kit at NAPA.
Rick
Threads: 23
Thanks for the responses. Took it by a shop this afternoon and they said it just needed the adapter fitting for the 134a. It looked like the prior owner or mechanic removed after the last a/c service. I'll take a closer look and report back over the weekend.
Thanks again,
Chris
'13 Lexus GX
'04 BMW 525
Threads: 51
You should really change out the drier when you convert to 134. Too bad the aftermarket driers don't have window glass anymore.
87 944S
19 Audi A6 3.0T
03 Toyota Tundra
