01-17-2016, 06:36 PM
The rain we got here in So. Cal brought with it a lot of moisture and condensation and after alternating days of sun and rain, I started getting a crunching sound in the passenger side fan. I thought it was the bearings and dreaded the thought of finding a replacement. I looked around and as it turns out used ones aren't that difficult to obtain and new ones are still available. So o.k. lets' tear it apart and see what's up. I discovered its not all that difficult to pull the whole assembly out. Remove the air-box and the large radiator hole on the driver side, disconnect the switch wire below it, that and the six bolts that hold the fan shroud, the two plugs that power the fans, a couple of retaining clips that hold the wires in place and out it comes.
Of course after 140k plus they look really grungy. There are 3 deep socket lock nuts that hold the motors in place. I unscrew them and out the motors come. The fans are held on by retaining clips. A screw driver pry's them off the motors axle. If you're careful you can reuse them, they're pretty robust.
And what is revealed... unbelievable amounts of soot. The armature is just covered with the stuff and if you shake the motor it comes out like a fine black powder, and in amounts that make you wonder that the motors ran at all.
The crunching sound was loud and the motor wirred, I thought its "catastrophe". And after seeing all that powder I'm truly amazed. I get a can of carb cleaner and spray into the armature from the front and there's a whole at the six o'clock position and spray it there. More black powder... now mixed with the solvent, the sink is black with it. After I cleaned it as thoroughly as is possible, I rotate the axle of the motor. No crunchy sound. I compare it with the other motor which is also saturated with the powder, but it did not exhibit the same auditory phenomena. They both sound and feel similar, so I clean out the second motor as well and figure that if the first motor doesn't work properly nothing lost but a little time.
I reinstall the fans... and voila! Both are running smooth as silk. I finished that a couple of days ago and both motors are operating properly.
I noticed about 6 months ago that the motors would resonate together for a time and then go out of sync. That presumably means that they are running at the same speed which creates a harmonic resonance. That fluctuation has gone which is the best indication I have that they are working properly. Worth looking into if you've got the time to spare, could extend the life of those precious fans.
