Threads: 4
Gene:
I just went through the same problem. The car I purchased apparently spent a lot of time sitting around and both sets of nozzles were clogged and attempts to clean them sufficiently failed to work well.
I just go through replacing both nozzles, (Sunset Imports - @ $24 ea.). Really a pretty easy DIY. There is a right and left because of the electrical connections. The main challenge was removing the electrical pins for the connector. The right tool would help but perseverance worked.
Dave Cz
94 Coupe White
MD, USA
Threads: 51
Bumping this thread to ask if anyone can recommend a source for high-quality tiny hose clamps for the washer nozzle hose. My attempts to clean one nozzle continue to fail - I think there's something bigger in there that will necessitate removal and re-connecting the nozzle after cleaning. The OEM clamps are the crimp-on type - I'd rather replace with screw-clamps if that's possible. Any thoughts?
Threads: 51
Ha! I did think of zip-ties - but then said to myself "naahhh... never work". However I didn't know about the metal variety ... I'm off to my McMaster catalog right now...
Threads: 51
Ouch! Good idea, rxter, other than the crunch part. I'll try your technique. PS - replaced both hood shocks this weekend. Made a big difference! Hood stays up now.
