Let me clarify ... the pump works ... it pumps fluid. My issue is that with the replacement pump. the low fluid dash light comes on. It didn't before.
I did purchase a 968 original pump in that it was cheaper to buy a used 968 washer fluid tank with pump than to just buy a new pump. I used the original tank and just swapped pumps.
My 60-year old brain has blanked out on where that second plug connects. The other one with three wires, plugs into the top of the pump. And from what I've read on the archive, the pump has a sensor to detect if there isn't any fluid. Is that correct?
I thought it might be useful to get some opinions before I remove the tank again ... which is pain to install since you have to remove the battery, wheel well plastic cover, and wheel.
