Threads: 13
I keep it at a worn wheelbearing.
I replaced them.at te right rear side twice in 14 years.
It makes a wonkytonky grinding noise.
Changing the bearing is an two hour job.
But you have to loose the nut from the axle. This one is tightend with 500nm. You need a big heavy tool for that and a lot of muscle power.
And inside the tip. There is no lsd I can asure you. I opened the differential long time ago when I supected the bearings. And there is only a differential inside and no lsd.
Threads: 167
Dan,
87 Posts and you still don't believe it's a wheel bearing???
:glare:
Threads: 13
You will take of the wheel after loosing the nut. And remove the brake caliper and the disc. After that you remove the axle and than. Take a big M24 spindle with fitting rings and pull the hub. After that remove the ring and then pull the bearing out of the aluminium trailerarm.
It took me two houres. But I am trained.?
Bearing cost 100 bucks.
Threads: 13
With the right tools you can do it without removing all from the underside of the car and without an alignment.
Threads: 167
Quote:I can lend another set of hands and some heavy leverage / " muscle " ...unless things are seized up with age , rust , etc...
You are describing yourself, right?
j/k
(This post was last modified: 04-27-2017, 08:19 PM by
94SilverCab.)
Threads: 13
It is a porsche 968. Never had the experience that things are seized up..
Only the screw from thervs plate inside the brakecaliper...
Threads: 13
Glad that my 968 has respect for me.?
(This post was last modified: 04-28-2017, 04:20 PM by
unknown4u.)
Threads: 45
I had the arnworx tool for the rear wheel bearings, with a 500nm impact gun did both sides in two hours, with new bolts in the cv joints
The bearings are the same as 5 series BMW, Alko trailers also use the same size, 42x80x42 deep groove dual row bearing
The total cost including parts was $100, I did this job end of last year just before my open heart surgery
Since then I have replaced both front bearings total cost $60, new front and rear rotors and EBC red brake pads (less dust)
Threads: 13
When you slam with a hammer on top of the bearing. Nothing will happen directly but after a couple of thousand miles it goes make noise. A low grinding noise. I can not describe it at an other way.
The bearing at the back is closed so cannot be repacked.
Otherwise there are many reasons why bearings go bad. Maybe hit a bump in the past or to much with a cleaner on the wheels.
So press the bearing inside and do not use a hammer while you are in there.
Threads: 167
Quote:https://m.youtube.com/watch?v=-A5kf5pXl4w
The grease that the manufacturer uses is less than great, caused a bunch of failures on track cars. Taking them apart and re packing with quality grease solved the problem
Excellent! Add that to my list
Threads: 13
Bad to hear that it was not an easy job for you. What gives you the most nerves of the job? Getting the nut loose or? Getting the bearing out the arm?
(This post was last modified: 05-21-2017, 11:07 AM by
unknown4u.)
