Took a long drive, new noise
This forum has been invaluable so far so thanks for all the help.
I took the car on an extended ride today so it could stretch its legs out and when I returned home I had a new rattle noise.
Sounds like it's coming from the clutch area (hope I am wrong)  Anyone have any ideas?
https://youtu.be/Vz1Z_yXZC20
Could be a lot of things, maybe just a loose heat shield.
Does it change with engine rpm? Clutch in/out? Can you hear it while driving?
Use a mechanic's stethoscope to see if it's coming from the bottom of the block, bell housing, or torque tube.
Agree.
Just had my car in for a torque tube bearing swap and there were loose and /or bent heat shields that were fixed. As the shields warm up they bend and rattle against the car in a way that does not happen when cold.
In my experience as rattle is not the sound that is heard from my clutch area.
pdxmike has good advice.
11-21-2018, 12:46 PM
05-23-2017, 11:17 AM
10-13-2016, 12:48 PM
