10-11-2016, 03:49 PM
As if all the noises this damn car - the Tip - keeps making weren't disturbing enough, yesterday mid-day when I started it ( that's after driving it from work to the soccer field at noon, where it sat parked for a couple of hours before I started it to go back to work ) as soon as it turned over there was an infernally loud screeching and rattling and shaking coming from the engine, after which it stalled . It sounded as if every bearing of every component in there either froze or broke into pieces with disastrous results. In my mind I thought either the alternator or the AC unit bearings froze, causing havoc with the belts and everything else connected to them, and then stalling the engine. So I popped the hood to check the carnage which I expected to see, but absolutely nothing seemed out of place. Checked the tension of all the belts and they felt ok, they all looked to be exactly where they should, but of course I could not see or test the AC or the alternator rotation. I though whatever damage was done cant possibly get worse so I asked a team mate to turn the engine on for for just one or two seconds so while the hood was opened I could see or hear what and from where that racket is coming. So he started the car and the engine turned and ran as smoothly as the purring of a cat. No screech, no rattle , nothing ! So we let it run for a minute and since it seemed perfectly "normal" I drove it back to the office. After work, with great hesitation and fear of that noise coming back, I started it again for the ( hopeful ) drive home. It ran as normal as can be for the entire hour + commute . Oh, while parked and running I also turned on and off the AC switch a couple of times to see if engaging the compressor made any difference - it did not make any difference , and I had cold air while was it was on - so I drove it home without any problem and that was that.
After an hour rest and a glass of wine to calm my nerves, I tested the battery voltage to see if maybe the alternator was what shut down causing that noise, but the battery voltage was fine as well. As it was this morning when I checked it. Drove it to work and it's still perfectly quiet . So...what in the world could that have been ?!
