Threads: 76
NC is in the midst of a nasty drought. As a result the 968 has not been subjected to many downpours the past few years. But Friday it was parked at work and got drenched for several hours. Getting in I noticed a growing floor mat wet spot on the left side just below the hood release. Tracing with my fingers I found water drops up the carpet wall and around the release.
Thoughts?
Ralph
'77 911S (RIP)
Threads: 2
[quote name='RPM' post='48905' date='Mar 9 2008, 11:09 PM']NC is in the midst of a nasty drought. As a result the 968 has not been subjected to many downpours the past few years. But Friday it was parked at work and got drenched for several hours. Getting in I noticed a growing floor mat wet spot on the left side just below the hood release. Tracing with my fingers I found water drops up the carpet wall and around the release.
Thoughts?[/quote]
Detached drain tube from sunroof can cause wet rear carpets .....possibly the front too ?
The cream coloured tubes run behind the interior trim panels.
968 Coupe Tiptronic.1992 Metallic Slate Grey.Japanese Import.Sport Classic wheels.Goodyear Eagle F1's.Janspeed sports exhaust,M030 brakes,Air-con,Promax Chip,K&N Filter.
Threads: 13
Is the fusebox really closed? This can cause the problem as you descirbe in the front.
