Threads: 22
I had the same problem last year I believe.
The drain hose is center dash behind the radio. It required taking the center console apart and small hands to get in there.
There is an earlier thread so you can do a search.
Carl
1992, Guards Red, Coupe, 6 spd., LSD, Drilled frt. rotors,
Threads: 142
<!--quoteo(post=81717:date=Oct 12 2009, 03:38 PM:name=DaveN)-->QUOTE (DaveN @ Oct 12 2009, 03:38 PM)
<{POST_SNAPBACK}><!--quotec-->Turns out the reason the hose was plugged is that the stereo installer had let a butt splice fall into the vents somehow; it wormed its way through the vent hoses and finally came to rest in the drain hose 2 years later.<!--QuoteEnd--><!--QuoteEEnd-->
Dave, we should give you the <i><b>Diagnosis of the Year</b> </i>award. Very odd!
Roland
Roland
